2007 arctic cat 500 fuel problem
Old Aug 22, 2016 | 08:39 PM
geary's Avatar
Default 2007 arctic cat 500 fuel problem
I am not getting gas to the spark plug, the carb is getting gas to the float bowl. I have cleaned the carb and used compressed air to blow out the jets. what do I need to check now? also how do you bench check an ignition coil.
Old Aug 23, 2016 | 03:37 PM
DirtDevil101's Avatar
I like to start by ensuring it's a fuel delivery issue...to test compression/valves and spark I shoot some starting fluid down the plug hole and see if it runs on that...if yes, then we can move on...if no, then you have other issues...
Old Aug 23, 2016 | 10:54 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Check values may need intake value adjusted...doing an compression check like mention in above will help to tell what next job willbe
murph4478
Jun 19, 2016 01:53 PM
gary45863
Where to Ride
Jun 6, 2016 06:35 PM
tecate1987
Jun 1, 2016 10:01 PM
lil cheese
May 30, 2016 07:44 AM
