Need help with timing on a 98 sportsman 500
So I replaced the stator and flywheel due to a no spark condition. It idles perfect but at wide open throttle it sputters and backfires so a new carb and starter long story now same no change in thinking its a timing issue but kinda at a loss
if you took the whole stator plate off without marking it, then yeah, very possible its out of time
if the manual doesnt cover it then opt would have to answer that, ive never had to do it on an atv...id first go back in and see if you can see where the bolts used to be on the plate, should be a cleaner circular looking spot if you didnt clean it....might give you an idea if its off or not
