Manco Talon - Linhai 260cc - Oil in air filter box
Old Sep 30, 2016 | 05:18 PM
res2fr's Avatar
Red face Manco Talon - Linhai 260cc - Oil in air filter box
I have an '05 that ran well in July when used a little, then stored it until 19th of this month. very hard to start and runs really bad when going. It was used a little by my son until it died. Started checking it out and found the air box full of oil and crank nearly empty. Need to get back out there to check the compression and I probably need to check the crankcase filter. Just wondering if others here might have any suggestions on what to look at?
Thanks in advance for any ideas that might be offered.
Robert
Old Oct 1, 2016 | 08:57 AM
Zrock's Avatar
Super Quad Patrol
your on the right track. Check compression first and go from their
Old Nov 23, 2016 | 01:38 PM
The Mechanc's Avatar
Do A compression test, anything under 8:1 it WILL be rings, we have changed every 6 to 8 weeks in the summer before we switched to foam filters. Hard to start and poor tick over is also a symptom of worn rings.
The oil in the air box blows in from the cam cover and is caused by excessive crankcase pressure due to work or stuck rings.
Not very environmentally freindly but we run the breather out the back over the gearbox not into the air filter.
90guy
Feb 11, 2021 09:15 PM
brinkkl2000
Oct 3, 2016 02:50 PM
Samuel-james Fisher
Sep 30, 2016 02:36 AM
Cesar408
Sep 26, 2016 07:30 PM
