What is this?
Old Oct 21, 2016 | 02:36 PM
Shane72's Avatar
Question What is this?
Please see attached. Can someone tell me what this screw does? So I have two of these Taotao 125's -- one of them has the screw, and the other one has it missing. Actually - it's more of a threaded rod-- the end of the screw is actually a nut. Not sure if I'm supposed to thread the nut all the way to top or what. Can someone advise?
Thank you!
Old Oct 21, 2016 | 02:55 PM
scootergptx's Avatar
Supersock
Hired Gun!
From what I see, it looks like that should be a stud for the exhaust flange. Got a picture looking up from the bottom?
Old Oct 21, 2016 | 03:08 PM
Shane72's Avatar
Okay, took a picture from the bottom side shooting up for you. I think the screw is to the left, being covered by the black pipe. Looks like I'm missing a matching one on the other side, and then that flange is hanging down as well?
Thanks again!
Old Oct 22, 2016 | 02:29 AM
Yes, exhaust stud missing, looks like there could be a bit of it still in the hole, if so it is a job for a specialist, getting broken studs out and re-threading holes is one of the most awkward and skilled jobs a mechanic has to do. A local motorcycle repairer or general engineering shop will be able to tackle it.
Old Oct 22, 2016 | 07:05 AM
Shane72's Avatar
Ah, got it. Thank you. So, we are attempting to fire these up for the first time today -- will they operate with this missing?
Thanks again!
Shane
Old Oct 22, 2016 | 08:44 AM
Supersock
Hired Gun!
You can, but don't run them too long. Not good for it to be sucking up the extra air. Bad for the valves.
Old Oct 22, 2016 | 09:27 AM
Zrock's Avatar
Super Quad Patrol
yes good way to kill the engine. I would definitely leave that removal to the pros. Getting a steel stud out of a alum casing can be a real PIA.
Old Oct 24, 2016 | 01:55 PM
Shane72's Avatar
Thanks for your help everyone! My buddy and I were able to get both of these up and running this weekend, including getting the exhaust mounted securely!
Cheers,
Shane
