2006 arctic cat 700 SE efi
Old Nov 4, 2016 | 05:48 PM
Joelenway's Avatar
Default 2006 arctic cat 700 SE efi
On my dash it flashes EFI and the speedometer goes up and down about 7 times. I can start it and the it flashes efi small under the clock on the display.. can't get any codes or find anything in the manual. Please help
Old Nov 5, 2016 | 04:28 AM
Usually if it's not throwing codes it's a wiring fault. Some are easy to trace down,other are not.Don't know how your manual is set up but should have a section on the speedo display and tests on it's harness connector pins that may help you track down the problem.
Old Nov 6, 2016 | 01:55 PM
Joelenway's Avatar
There is nothing in the manual that I have.
Old Nov 6, 2016 | 07:54 PM
hydrex's Avatar
Just for chits and giggles, check the battery voltage. Low voltage can cause fits with efi.
Old Nov 6, 2016 | 08:02 PM
Joelenway's Avatar
It runs great no sputtering starts right up. Just flashes EFI all the time.. I'll check the battery
Old Nov 7, 2016 | 02:30 AM
Try disconnecting the battery for a minute or so and hook it back up and see if the speedo clears.
Old Nov 8, 2016 | 08:57 PM
Joelenway's Avatar
I unhooked the battery and reconnected it and nothing changed..12.7 volts when not running and 14.2 volts while running..
Old Nov 9, 2016 | 03:27 AM
Then possible it's an internal speedo problem. Only way to tell for sure is if the dealer has the software that can check out the system. May be worth the trip versus hunting for a short or checking though all the connections not knowing what you're looking for.
Old Nov 9, 2016 | 04:55 AM
Joelenway's Avatar
The speedo is new with 130 miles on it.
Old Nov 9, 2016 | 05:02 AM
Doesn't mean it can't be faulty even if new,but there should at least be something in your manual on the efi system that might help you trace down the problem whether it's a relay or breaker of some sort,bad connection or it should show how to check the pressure on the fuel pump along with checking voltage to the fuel injector.If the gauge is ok,something is triggering the efi light.
