water cooling thermostat assembly help
Old Dec 1, 2016 | 10:10 PM
x-rider's Avatar
Default water cooling thermostat assembly help
CG 200cc water cooled engine. I need help or pics of how to hook up temperature sensor etc. for an engine swap on a honda 200x. Pic of thermostat assembly above.
Old Dec 2, 2016 | 12:30 PM
x-rider's Avatar
Obviously the large one goes to the radiator. The upper one me and another guy figure is for a fan sensor switch. (Ground?). I'm not going to run a fan, so I shouldn't need it. That leaves the lower brass barb fitting. Is this just a drain in case of a seal failure?
Old Dec 4, 2016 | 05:43 PM
x-rider's Avatar
Please help. I just need to know how/where the low brass fitting connects to. There has to be some liquid cooled quads out there with the same or similar thermostat assembly.
Old Dec 4, 2016 | 06:54 PM
x-rider's Avatar
I think I got it figured out. I found a pic on the Internet and it looks like it ties into the radiator
Old Dec 5, 2016 | 09:53 PM
x-rider's Avatar
Just another reference photo.
Old Dec 6, 2016 | 03:06 AM
It will be the thermostat by-pass hose.
That temp sensor can be used with a warning light, but if you are fitting a temp gauge, you need a different sensor.
Old Dec 6, 2016 | 08:54 PM
x-rider's Avatar
Thanks for the info about the warning light/ temp guage.
