06 200cc blaster shifting issues
Old Dec 5, 2016 | 01:17 AM
Malaktjn's Avatar
Default 06 200cc blaster shifting issues
So I bought a 200cc Yamaha blaster a couple months ago and recently I've started having issues with shifting where it won't always shift up or down without trying 3-6 times. Or I'll have to go up a gear then down 2. Anther issue I'm having is the shifting level with get stuck up after I shift and I'll have to tap it down.
Old Dec 5, 2016 | 11:10 AM
Danulson988's Avatar
Default check your shift star.
Had the same problem on my 98. You have top remove the clutch basket to have easy access to the shift star bolt. On mine, the bike started to drop out of gear between 2-3 and then started not shifting sometimes. The bolt that holds the shift star was loose. Put blue loctite and tightened back up. Shifted like new after that. The star should be tight with no wobble. Check for wear also.when you remove basket, the star is bottom left.
Old Dec 5, 2016 | 12:48 PM
Malaktjn's Avatar
Mine will mess up when either down shifting at any point and it's a pain to find neutral. Sometimes it'll get stuck up and it will shift if I tap it back down but other time I just won't be able to shift unless I let the clutch out and then try shifting after a little bit. I'll check out the star bolt and let you know how it goes thanks
