Northstar wiring issue and other questions
Old Dec 15, 2016 | 05:42 PM
mrnapolean1's Avatar
Default Northstar wiring issue and other questions
I have a Northstar Chinese ATV that I got on a trade. It would crank and run but only with a stream of carburetor cleaner going in it. (carb gummed up)
So I ordered a new carburator for it and I install it, put some gas in it and try to crank it but It does nothing. The headlights work, the N lights up but when the starter button is pressed it does nothing. I tested the continuity of the button and there's continuity when its pressed.
So I go find the starter solenoid and I jump the solenoid (did this for years on a lawnmower back in the day) and all I get is crackling at the battery connectors. It sounds like a direct short to ground.
So I am deciding to weather I should attempt to fix this crap or just rewire it like its supposed to be?
I cannot find a readable wiring diagram anywhere.
If I do decide to rewire it, I am going to need some help on charging and starter wiring, and as well wiring for the coil.
Old Dec 16, 2016 | 06:07 PM
I found out the culprit. It was the starter Solenoid.
I ended up rewiring it for a three post solenoid off of a troy built lawnmower.
Here are some pictures:
This was my quad in the testing state:
Here is the information about the solenoid I used:
And the finished product:
Old Dec 17, 2016 | 09:16 AM
Zrock's Avatar
Super Quad Patrol
i would just go get a automotive solenoid. cheap and reliable
Old Dec 17, 2016 | 07:09 PM
I had this one lying around. Just had to take it off the junk mower it was on.
But you're right If I had to buy a solenoid, It would be a one that fits a 80s model ford F100 with the 4.9 300 L6. Best solenoid out there.
