85/86 moto 4 200 clutch issue
Old Feb 7, 2017 | 11:26 AM
motoboss's Avatar
Default 85/86 moto 4 200 clutch issue
Hi all, I have a 85/86 moto4 200. I put new friction and steels in an when I go to tighten up the cover an check to see is shifter if works is locked up. I can shift through gears with cover off fine. It seam like the shift shaft is binding on cover. Why? Thanks newbie
Old Feb 7, 2017 | 01:48 PM
Recheck your work on the shaft,may not be fully inserted causing binding if it was working ok before. Either that or possibly a burr on the shaft or case bushing.
