How many pounds of compression is good... Banshee???
Old Dec 25, 2003 | 06:04 PM
MX660R's Avatar
Default How many pounds of compression is good... Banshee???
I just got a compression tester for christmas and was wondering how many pounds is good for a banshee. I got a reading of 118-119 pounds, sounds about right to me, but just checking what they are supposed to be.
Old Dec 25, 2003 | 06:34 PM
87Banshee250sx's Avatar
Perfecto. Once it starts fallin below 100 or so, u might wanna loook at a rebuild. Otherwise, thats a very good number. [img]i/expressions/face-icon-small-smile.gif[/img]
-Nick
Old Dec 25, 2003 | 07:07 PM
MX660R's Avatar
Thanks Nick, It was just rebuilt a little while ago, that may acount for the decently high numbers!
Old Dec 25, 2003 | 09:38 PM
Hozed's Avatar
high?
my my buddies shees run at about 130-150
Old Dec 25, 2003 | 10:05 PM
DuneDevil's Avatar
It depends on your altitude, and if the motor was warmed up or cold.
Make sure you hold your throttle wide open when you take the test. And turn off the fuel and ignition.
DuneDevil
Old Dec 25, 2003 | 10:55 PM
hondaracer305's Avatar
Yah, i had to rebuild when my banshee wouldnt fire with 60 lbs compression, like the others said, 100+ psi is what it should be.
Old Dec 26, 2003 | 02:05 AM
Hiram's Avatar
Reading higher than 120 are usually the result from shaved heads
Old Dec 26, 2003 | 02:20 AM
Hozed's Avatar
hmmm.. one of my friends has a cool head with 22cc domes.. and the other is stock..
all you do is stick the tester in the plug hole and kick it over right?
they usually run over 135psi easy...
Old Dec 26, 2003 | 02:33 AM
440EX026's Avatar
its a combo of compression created and contained.
diff pistons, gaskets and heads can all change the numbers.
Old Feb 10, 2017 | 10:04 AM
Sean Doble's Avatar
Originally Posted by Hozed
high?
Mine runs at 130-140
Scooter's Shop
Oct 9, 2015 02:09 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
