Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
How to bond/seal transmission case
Old Feb 18, 2017 | 08:46 PM
asellers01's Avatar
Default How to bond/seal transmission case
Need proper way to seal transmission case. I have Polaris sealant, 2871557 Sealant, which is the recommended from the service manual. What's the proper technique? Thin layer, small beads? I couldn't find another post.
Thanks,
Asellers
Old Feb 19, 2017 | 04:13 AM
I actually used a thin layer of Three Bond on each case half. After the cases are together let it set over night and then you can use a razor blade to remove any external sealant around the gear case. Polaris sealant is the same as Three Bond,but called 3 Bond.Actually it's Three Bond 1215. I used 1104 until it was replaced by 1194 because of lead.All of these are good for cases.2871557 SEALANT,5OZ.3 BOND 1215 $24.99
Attached Thumbnails How to bond/seal transmission case-three_bond_1215_250g.jpg
Old Feb 19, 2017 | 09:40 AM
asellers01's Avatar
Thanks. Should I worry about bond that squeezes to the inside?
Old Feb 19, 2017 | 02:20 PM
Not on a thin finger layer around each case half,keeping away from the inner edges of the case. Reason I did both sides is that many cases are irregular,can have gaps and possibly leak if not enough is applied.Nothing worse than having to split one back open for something as trivial as this.Again after any possible excess is exposed to air and hardens, you can use a razor blade to remove. Just be sensible when using sealants.
