Clutch grinding noise
Old Apr 6, 2017 | 06:38 PM
Vtwinproblems's Avatar
Default Clutch grinding noise
Hello there I am a owner of a 2004 Arctic cat 650 vtwin, I'm currently experiencing a grinding noise coming from the primary clutch area; I have the cover off and nothing physically to explain the noise; it gets louder and louder the more you accelerate; has anyone experienced this issue? Please help
Old Apr 6, 2017 | 07:10 PM
Doesn't make a sound in neutral or with belt off
Old Apr 6, 2017 | 07:45 PM
hydrex's Avatar
I would check any bearings in there. Download a parts manual from <mymowerparts.com> You should be able to identify the location of any bearings. May be easy, may be a real pita.
Old Apr 7, 2017 | 08:08 AM
Do you think it could even be there U joint in rear drive shaft? Cause I just have learned they are completely shot, it's flange on flange; and that would explain why the noise doesn't occur in neutral right?
Old Apr 7, 2017 | 11:02 PM
hydrex's Avatar
Well, you gotta fix it anyway, you are probably right. I looked at the parts manual for that model, no obvious bearings to fail, so.... BTW, when I bought my Diesel used, it had a heck of a rattle in the CVT area. Took off the cover, bingo- there was a 3/8" drive Harley Davidson socket in there, floating around!
Old Apr 12, 2017 | 07:59 AM
Alex G.'s Avatar
If it's not happening in neutral or with the belt off, then it's most likely in the driven 1/2. Sound like you might have found it with the U-Joint issue.
Old Apr 19, 2017 | 12:27 PM
Alex G.'s Avatar
Did you finally figure it out?
