KVF 650 Ignition
Old Apr 28, 2017 | 12:19 PM
Rdmster508's Avatar
Default KVF 650 Ignition
Hi
I have a 2002 KVF 650 and with the key off, some lights in the panel are still lit and it drains the battery..
I replaced the ignition switch last fall and all was good till a couple weeks ago..
Any thoughts would be appreciated
Thnx
Ron
Old May 1, 2017 | 02:40 AM
Never worked on a KVF 650 but nobody else has answered, so. Try disconnecting the new switch, if the lights go out, your new switch is bad. Can't see any reason why your machine should eat switches, unless you have something extra, that takes a lot of power, wired through it.
Old May 1, 2017 | 07:49 AM
Rdmster508's Avatar
Thanks Merryman will try that later today and will let you know what happens..
Only accessories I have is a winch , but that is hooked directly to the battery.
