red
Old May 3, 2017 | 11:25 AM
red57's Avatar
Default red
starter stays engaged after engine starts, and when you turn the key off continues to crank. 05 Polaris sportsman 800
Old May 5, 2017 | 04:25 AM
IF the starter motor itself is continuing to run,then either the ignition switch may be sticking(a common problem) and needs to be replaced or a wiring short to the switch.Either that or the solenoid has shorted out allowing constant power to the starter which I've had happen also.Both are pretty cheap.http://www.ebay.com/itm/Ignition-Swi...VX45EG&vxp=mtr
http://www.ebay.com/itm/Starter-Sole...hXEm5A&vxp=mtr
