Foreman charging problems
Old May 9, 2017 | 08:58 PM
Cooncatcher20's Avatar
Default Foreman charging problems
I am working on fixing a charging problem on a 2000 Honda foreman 450 s.I have replaced both the stator and the rectifier and tested both and it still will not charge the battery.Any advice would be helpful.
Old May 9, 2017 | 09:56 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Are you getting 12 volts to reg/recf? Does have an ground ?
Old May 12, 2017 | 06:53 PM
Ajax's Avatar
If you have it running what does the volt meter reat at te battery? During idle and while reving it?
Old May 12, 2017 | 10:06 PM
It reads about 11.86 while off and does not change when running.
Old May 12, 2017 | 11:01 PM
It reads 11.86 turned of and the reads the same running.
Old May 12, 2017 | 11:43 PM
Yooper265's Avatar
Have you checked the 30 amp fuse ?
Here's a link for the { free } service manual if you don't have one -
Index of /service-manuals/honda
Old May 13, 2017 | 02:25 AM
Did you try testing at the regulator, like papa hog scoot wrote? I use a test lamp for this as you sometimes get a voltage there but little power, and any resistance between regulator and battery causes the regulator to stop charging.
Old May 13, 2017 | 07:24 AM
Ajax's Avatar
If its anything like the 1999 450 es i just wrestled with (and won!) It will blow that fuse repeatedly if the Regulator is bad. It also wont show any power getting beyond the Reg (to battery) so testing before it is a great/simple way to verify whats what.
The regulator i got was like $20.00 off ebay and has been working great.
Heres an image that should help..
Old May 14, 2017 | 01:54 AM
The 350 will, almost always blow the main fuse. The 450 usually just won't spark if the regulator goes bad. There are always exceptions, and possibly Ajax's machine already had a 350 regulator fitted as they go on, and are much cheaper than that strange un-finned black box that Honda fitted originally.
Old May 20, 2017 | 09:58 AM
Well the fuse was the problem and now it is charging great thank you.
