Warrior Filters
HI,
I have a 2001 Yamaha warrior 350. I went to check the air filter and oil filter since I just bought it, and it seems to be that the air filter sits in loosely? I'm not sure if that's right, or of it is supposed to be a tight fit? But there was no way that this filter would lock in anywhere at all. Also, I did an oil change and went to check the oil filter. I took out the oil filter, and it was tight in there, so I yanked it out. However, my thumb left a small dent in it. After inspection I found that the filter wasn't dirty and didn't need to be finished, so I went to put it back in. Somehow I could not get it t fit snugly like it was when I took it out. It was a loose fit, so I just put the cover back on and left it until a later time. Is that dent I out in it bad, and how is the oil and air filter supposed to fit?
Thanks
Thanks
