95 timberwolf
Old May 11, 2017 | 01:47 PM
Rgokey0778's Avatar
Default 95 timberwolf
I bought a 95 timber wolf and the problem is when I am down shifting there is a grating noise. It only happens then not while going up in gears. Any ideas.
Old May 12, 2017 | 01:44 AM
Adjust the clutch for a start. Not sure why it would only grate going down, but the clutch not disengaging properly would cause the gears to grind.
Old May 12, 2017 | 09:52 AM
Rgokey0778's Avatar
I did adjust the clutch with no change. This kind of has me stumped
Old May 12, 2017 | 04:57 PM
Ajax's Avatar
Bent shift fork can cause this aswell. does it do it while at idle if you just run up and down through the gears? only when under load?
