2008 polaris 500
Would help to know a little more info.Check that you have power going to the starter cable with a simple meter or test light. If so might as well replace the starter and bendix. You can loosen the starter nut and turn the cable and tighten the nut. Could be a bad connection.If you don't have power to the starter,could be a faulty solenoid,battery,corroded or loose connections.
stan5686
Sep 4, 2016 04:07 PM
