2008 polaris 500
Old May 18, 2017 | 09:57 PM
mcgrath1's Avatar
Default 2008 polaris 500
starter won,t work
Old May 19, 2017 | 01:53 AM
Would help to know a little more info.Check that you have power going to the starter cable with a simple meter or test light. If so might as well replace the starter and bendix. You can loosen the starter nut and turn the cable and tighten the nut. Could be a bad connection.If you don't have power to the starter,could be a faulty solenoid,battery,corroded or loose connections.
MikeyT
Sep 6, 2016 03:50 PM
stan5686
Sep 4, 2016 04:07 PM
steelhead loco
Aug 8, 2016 06:55 AM
eyeowa
Utility ATVs
12
Jul 20, 2016 03:00 PM
eyeowa
Jul 18, 2016 06:48 PM
