Need help on a rubicon
Old May 22, 2017 | 03:29 PM
Tattoodad5's Avatar
Default Need help on a rubicon
..hi everyone I'm new to this site..I have a 2001 Honda Rubicon 500 hondamatic.. the machine acts like it's stuck in high gear..I have replaced the shift angle sensor,,shift motor,,oil change..reset code procedure,. The shift motor will not initialize but one time and manual said it's suppose to do it three times...any help would be greatly appreciated..I've seen alot of these questions but really no answer..thanks in advance
Old May 22, 2017 | 09:09 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Did you preload angle sensor?
Old May 22, 2017 | 09:10 PM
Loved
Community Favorite
Welcome aboard
Old May 22, 2017 | 09:11 PM
Loved
Community Favorite
Does your speedo work?
Loved
Community Favorite
What code was atv displaying?
Old May 22, 2017 | 09:27 PM
Tattoodad5's Avatar
Default Need help
Yes..speedo works and I preloaded the sensor..cleared all codes...codes 5 will pop back up but can cut switch off then back on and no code
Old May 22, 2017 | 09:29 PM
Tattoodad5's Avatar
Plus the shift motor will not initialize
Old May 23, 2017 | 02:54 AM
If it is a new shift motor, and you know it is good, my guess would be a problem with the power supply to it, i.e, it isn't getting power on the green/red and orange wires from ECU to motor. Another possibility is a mechanical fault, something stuck, so the motor can't turn the mechanism. Try changing gear with the motor out of the gearbox, if the motor spins, then you probably have something jammed.
