2005 Sportsman 700 EFI...
Old Jun 4, 2017 | 10:30 AM
JCDEYO25's Avatar
Default 2005 Sportsman 700 EFI...
Thowing a code 41... Machine won't start or even turn over..when in diagnostic mode battery is reading 9.5 which I know is low. It's an Odyssey PC925 which has been in the quad since prolly 2009-2010.. Any ideas?
John
Old Jun 4, 2017 | 12:59 PM
Charge it up and load test the battery. Any auto supply can do it. Or you can check load with a meter.https://www.batterystuff.com/blog/ho...ry-is-bad.html
Old Jun 4, 2017 | 01:54 PM
JCDEYO25's Avatar
Ok OPT.. Thx. I"ll get right to it..How bout the code 41?Possibly T bap related but its been running fine I replaced it once with oem but I know of the Only The Best too
John
Old Jun 4, 2017 | 02:34 PM
Codes can pop up when battery voltage drops also. If the code remains after you check/replace the battery and it has symptoms of a tbap problem such as hard starting,erratic idle or back firing,then could be the connector or the thin wiring on the tbap sensor. Usually sensors themselves aren't the problem. OTB has better harness repair kits than what I had from Polaris.https://otbpowersports.com/products/
Old Jun 4, 2017 | 02:52 PM
JCDEYO25's Avatar
Ok I'll let you know. Thx again
John
Old Jun 14, 2017 | 07:51 PM
JCDEYO25's Avatar
Just a quick update cause I hate when people post and never update what the outcome was.. My buddy tested the battery and said it was junk.. The date on it was 11/07 so I almost got ten years out of it.. So I put in a new Odyssey and it fired right up.. No codes..Thx for ur help OPT..
John
Old Jun 15, 2017 | 04:10 AM
10 years on a battery.. You got your money's worth on that Odyssey battery. Glad a new one solved the problem and also that you replied back for everyone. Same complaint here and from a lot of people on hit and run posts.
