how much power do you get from a airfilter/jet kit combo?
Refresh my memory, is the Beartracker a 250? Im guessing that between a filter, jet, pipe combo that you will pick up about 3hp. Wont be much by the seat of your pants but it will help throttle response and may remove any flat spots in your powerband. I have 2 utility quads and they are both bone stock.Since utility quads have less agressive cams, compression and displacement they are less likely to respond to mods.Im not telling you what to do with your equiptment but Id leave it stock.The $300+ you could save by not getting a pipe, filter ect would allow you to buy a good set of tires which will do more for a utility quad than any pipe could, especially if it is a 4wd.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
