finally found oil leak but how to fix?
Old Jul 3, 2017 | 07:59 PM
95scramblerruben1033's Avatar
Default finally found oil leak but how to fix?
as per subject line i finally found the oil leak that had plagued me for about the last year. It is coming from the shifter pedal now is it really hard to fix it.
THANKS IN ADVANCE
RUBEN
p.s. i almost forgot to list my machine it is 2001 kawaski lakota sport.
Old Jul 4, 2017 | 05:15 AM
Sounds like a shifter seal leaking.Should be easy to pop out and install a new one.2001 Kawasaki LAKOTA SPORT (KEF300-B1) Engine Cover(s) | Babbitts Kawasaki Partshouse
Old Jul 4, 2017 | 10:56 AM
okay thanks OPT is there a way to go about taking it apart, and which number in the diagram are you sure that this is the diagram i should be looking at because it seems as it is on the other side, i mean the actual shifter is on the other side it would be the left side if you were sitting on the machine.
THANKS IN ADVANCE
RUBEN
Old Jul 4, 2017 | 02:55 PM
If the chain is on the left side #12053 is the chain guide. May be wrong but looks like one of the 92050 seals would be for the shift shaft,the other 92050 for the sprocket seal.Could be wrong.
Old Jul 5, 2017 | 09:43 AM
okay thanks OPT. now how would i go about taking it apart is it a very difficult job.
THANKS IN ADVANCE
RUBEN
Old Jul 5, 2017 | 09:52 AM
If your going to work on any machine new to you just get a manual.https://www.tradebit.com/filedetail....pair-1995-2004 Can save you time and frustration.
Old Jul 5, 2017 | 10:56 AM
okay thanks OPT.
RUBEN
