Castle nut won't get any tighter
Old Jul 4, 2017 | 05:31 PM
abonnette86's Avatar
Default Castle nut won't get any tighter
There is slight 'play' where the hub meets the axle causing the wheel to rock from side to side a few millimeters. I tried tightening the castle nut but at a certain thread it just spins...the axle and hub bolts are not where the play occurs. Do you think the castle nut just needs to be replaced? When i remove the washer the castle nut will tighten all the way but of course i need the washer present.
Sorry forgot to add - 2003 Raptor 660
Old Jul 5, 2017 | 02:50 AM
Sounds more like the axle threads worn, if it will tighten on unworn threads. Try a new nut but be very careful not to overtighten (use a torque wrench). I am unfamiliar with the Raptor but would be tempted to leave the washer off, or find a thinner one, if possible, as a loose nut makes the splines wear rapidly, and you would soon need a new shaft.
Old Jul 5, 2017 | 05:12 AM
thanks. the nut that was on there was not a lock nut like the other side, so its likely the previous owner lost the original and replaced it with a generic bolt that junked up over time. i could use a thinner washer but want to make sure its thick enough to handle the lateral pressure. but i think i'll pick up locking castle nut and if thats not it whatever i wasted $5...
Old Jul 5, 2017 | 08:16 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Try 2 washers.
Old Jul 5, 2017 | 10:35 AM
hydrex's Avatar
If you have any doubts, replace any worn parts with new. If a wheel comes off at speed, it could hurt.
richardw
1) Engine problems..
Mar 21, 2013 10:09 AM
