2009 Ranger XP 700 Surges
Old Jul 25, 2017 | 06:03 PM
TCJM5300's Avatar
Default 2009 Ranger XP 700 Surges
700 XP Starts, Idles and accelerates fine for two seconds, then the RPMs drop, doesn't stall or run rough, just won't stay at higher RPM.
Old Jul 25, 2017 | 06:38 PM
First thing I'd do is check fuel pump pressure.If it's holding less than 39 psi a new fuel pump could solve the problem.Plenty of these for your model on ebay or amazon.Even Polaris shows a #2204306 replacement pump kit,but expensive.If the fuel pump pressure shows ok,then the problem could be a problem in the tbap or tps wiring harness problem that many have had. Codes may or may not be thrown on these two items. You can check for any any obvious bare wires or soft feeling wires where the wiring from the sensors lead back to the main harness. Usually not a sensor problem itself,just the connector or wiring leading from each one. Better harness repair kits are offered here.https://otbpowersports.com/products/
rjestes3
Kawasaki Side by Sides
Apr 27, 2019 10:49 AM
gadawg31
Nov 18, 2016 01:27 PM
rjestes3
Oct 25, 2012 04:06 PM
SinCityRanger
Polaris Side by Sides
Oct 19, 2010 10:38 PM
GretnaRyder
Dec 15, 2005 11:58 AM
