Polaris Ranger crew 500 sticks in first
Old Jul 29, 2017 | 09:35 PM
Ron Cooper's Avatar
Default Polaris Ranger crew 500 sticks in first
I was out riding today for about 2 hours, I was coming out of the woods when my Ranger would not come out of first gear. It idled high and would not go past 20MPH. I have a 2013 Polaris Ranger Crew 500 and I took it home, replaced the oil and transmission fluid and tested it. it seemed to run fine but if it happens again what could it be?
Old Jul 30, 2017 | 06:04 AM
Make sure simple things like the throttle cable to the throttle body isn't in a bind,check the tbap and tps sensor wiring for any bare or soft spots plus a simple leak on the tbap grommet can cause idle problems.Hard to shift gears if idle is too high.If the grommet is worn or split replaced it. Item #9.
