110cc motor bogs from half throttle onwards.
Old Aug 7, 2017 | 01:53 PM
tweeder's Avatar
Default 110cc motor bogs from half throttle onwards.
It was running fine last year when it was put away. It has new fuel and i sealed the two gaskets at the carb and the intake to motor. It starts up and idles fine but i just cant get it to rev past half. I have sprayed carb cleaner to clean it. I have tried with the fuel screw all the way in and out to 2 turns, it seems to get worse the more i turn it out. Its no different with the choke on but choke makes it worse when its warm.
Old Aug 10, 2017 | 02:16 AM
Try a new plug, and check the battery voltage isn't going over 15v as you rev it up. Probably is a carb problem though, so clean the jets out with compressed air, if the electrics are OK.
Old Aug 10, 2017 | 09:00 AM
hugemoth's Avatar
Any chance a mouse built a nest in the air filter box and restricted the air flow?
