2005 Honda Rancher 350es. Please help!!!
Old Aug 7, 2017 | 04:39 PM
TimberGhost90's Avatar
Default 2005 Honda Rancher 350es. Please help!!!
I've got a 2005 Honda Rancher 350es. I was riding a few days ago and turned off my at, no problems. Went to start it back and nothing with the start button. I pull started it and it fired right up. Came home and parked it now it won't do anything. I can turn the key on and even try to switch gears with the electric shift but nothing. The speedometer doesn't work. Hasn't worked for some time now so the lights wouldn't show up neutral or not. The other night we was trying to start it with the pull start but still nothing. No spark. It's not doing anything. Any advice would be greatly appreciated.
Old Aug 7, 2017 | 09:39 PM
Kymco 450i's Avatar
First thing I would check is the charge on the battery, needs to be 12.6 volts or more, anything less and these Honda electric shift models don't work well.
Old Aug 8, 2017 | 01:11 AM
Check the main 30 amp fuse, there is one for the ES motor as well, so be sure you are checking MAIN. If it is blown, disconnect the voltage regulator before fitting a new fuse. Switch on, and if everything works and the fuse doesn't blow, re connect the regulator. If the fuse then blows, you need a new regulator.
