Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Need help with jetting
Old Aug 15, 2017 | 09:23 AM
Ghv72003's Avatar
Default Need help with jetting
Hi guys very new to this i just bought 2 banshees,they are both 2000 onw has a 34mm keihin pj carb with t5 pipes k and n filters and suposobly it has been ported i live in los angeles at the moment temperature is around 85 at sea level what do you guys think my pilot and main jets should be everything else is stock.
The other one has 28mm pwk carbs with kand n filters and fmf pipes same question what my jetting should be
Old Aug 15, 2017 | 10:25 AM
DirtDevil101's Avatar
How are they running? I'm guessing something doesn't feel right or why would you be asking. Because these are larger than stock and both machines are modified there is no real baseline so asking what your jetting should be is a tough one. You may find some success on a banshee specific site with similar modes...but the porting (amount of) can make a big difference.
If you don't have an A/F pipe sniffer then you can always do a plug chop (at least to get the main close)...if you are unfamiliar let me know and I'll walk you through it...
Old Aug 15, 2017 | 11:02 AM
Ghv72003's Avatar
You are right they don't feel right the main reason i ask is because they both have a 160 main
Old Aug 15, 2017 | 11:03 AM
Ghv72003's Avatar
And one is ported with 34 mm carbs and i don't think thats right
Old Aug 15, 2017 | 11:05 AM
Ghv72003's Avatar
What is a A/F pipe sniffer?
Old Aug 15, 2017 | 11:28 AM
Ghv72003's Avatar
hh
Old Aug 15, 2017 | 12:19 PM
an a/f sniffer is a wideband o2 detector...it measures the a/f ratio...that's what a dyno shop/mechanic would use.
The best way to tell if you're lean/rich at the main is to do a plug chop:
1) warm the machine up
2) find a long stretch of open ground
3) run it at WOT for a good ways
4) while at WOT kill the engine and release throttle at same time
5) pull the plugs...looking for tan color like cardboard...if whitish go up 2 jet sizes...if darker go down 1 jet size...running a little rich (darker) is ok, running lean is not ok...
this takes patience and time...you may find the 160's are ok...you may not...but you need a baseline to work from before doing anything!!!
Old Aug 15, 2017 | 12:43 PM
Ghv72003's Avatar
You think is normal for both machines to have a 160 main?
Old Aug 15, 2017 | 01:58 PM
Well...you THINK the other one has porting...so I can't say one way or the other.
I think it best that you find out what's really going on...that's what I think...
Old Aug 15, 2017 | 06:33 PM
Ghv72003's Avatar
Ok thanks
