My2006 sportsmen 450 will not move in high gear but does in low
Old Aug 27, 2017 | 06:35 PM
Donald Johnson's Avatar
Default My2006 sportsmen 450 will not move in high gear but does in low
My2006 sportsmen will not move in high gear but will in low .belt is new
Old Aug 28, 2017 | 02:30 AM
First thing I'd check is the outer gear shift quadrant behind the small plate that has given people problems over the years. It could be just corrosion from water that needs to be cleaned up or a gear problem. Here's a gear case on a 700 that has the same basic shift set up that one owner cleaned up. Courtesy of Polaris Atv Forums.Hard to Shift 700 Sportsman 2004 - Polaris ATV Forum The manual can help also and shows step by step on this as far as having the gears indexed properly.2006 Polaris Sportsman 450 Service Manual PDF Download
Attached Thumbnails My2006 sportsmen 450 will not move in high gear but does in low-6860984e7879f40967c0269470f12c3e2c8cfbe8.png
kinuski
Feb 17, 2006 01:12 AM
