Xped axle help
Old Aug 28, 2017 | 03:16 PM
mech5.6's Avatar
Default Xped axle help
i am having a terrible time getting the pass side roll pin out of the axle, i used PB a roll pin punch and a two pound hammer for two hours and it did not budge except to peen the end, any ideas and if not how can i get the front diff out to get it on a bench where i can really hit it?
Old Aug 28, 2017 | 04:13 PM
I learned real quick to use an air hammer to remove roll pins after banging my knuckles with a hammer. Air impact with a ground down bit usually makes short work of removing these frozen roll pins,or at least out far enough that you can finish removing it a standard punch and hammer. You can get extended length impact bits also to use on hard to reach pins.Always use a new one when reinstalling the drive shaft.
Old Aug 29, 2017 | 08:14 AM
mech5.6's Avatar
thanks i will try that!!
Old Aug 31, 2017 | 04:18 AM
switzomatic's Avatar
And don't bother replacing it. I always remove them when I get a new machine and replace with a nylock nut/bolt that fits in snug and just long enough to thread the nut on. Coat the bolt with some never seeze and you'll be good to go!
