Help!!!!!!
Old Aug 29, 2017 | 02:40 PM
Kristin's Avatar
Default Help!!!!!!
I have a 1985 Suzuki Quadrunner LT230g I need a u-joint drive shaft and I can not find one anywhere.
Old Aug 29, 2017 | 02:44 PM
Kristin's Avatar
I don't even know if that is the right name to the part so im search everything wrong
Old Aug 30, 2017 | 02:46 AM
No price on the on-line parts list, 1985 Suzuki LT230G PROPELLER SHAFT - FINAL DRIVE GEAR | Babbitts Suzuki Partshouse so it must be no longer available. It is shown as a unit with the splined couplings, so if it is only the UJ spider assembly that needs replacing, you may be able to remove it from the yokes, and find a standard UJ that will fit. This is a long shot as the bearings will probably be peined into the yokes and may be an odd size. The half shaft UJs on later IRS 250s are like this (but half shafts for them are still available). If anyone knows of a "work around" it will be Suzuki dealers. Other option, a good one from a breaker.
