Need Help
Old Aug 29, 2017 | 06:54 PM
mguidry43's Avatar
Default Need Help
I have a 2005 John Deere Buck 650 4x4 and I'm reading that it's the same engine as the Quest. My bike's solenoid went out about 6 months ago and I just got around to changing it out. When I got it started I noticed there was an oil leak accompanied by a knocking noise. I fixed the oil sensor that was leaking but the knocking noise is still there. When I changed the oil I did notice metal shavings in the oil and on the oil filter. Any idea on what this could be or what I could be looking at to get it fixed? Any help is appreciated.
Old Sep 3, 2017 | 09:48 PM
Hardly's Avatar
Doesn't sound good by your description...oil sending units can leak oil out quickly and if you were riding and got low on oil and didn't notice ...yuck...if its a deep knock it could be a crank bearing,if its not so heavy but still quite noticeable it could be a wrist pin at the top of conrod...You should have someone in the know listen to it before you ride it any more...Jmo...Good luck
Old Sep 3, 2017 | 11:57 PM
mguidry43's Avatar
Thanks, the noise seems to be coming from the top end of the engine. Hopefully it is that, I have never torn down an atv engine but I think I can handle it. Seems like the rod bearing would be easier to change than the case
Old Sep 9, 2017 | 08:11 PM
Hardly's Avatar
Yes if you get it quickly and not to many filings in oil you may be ok. good luck.
