800 EFI maintenance tips
Old Sep 8, 2017 | 07:21 AM
thedon's Avatar
Default 800 EFI maintenance tips
Do the drain plugs need the rubber washers? Only my rear axle had one and it was broken. Front axle, oil and trans all didn't have one and I have not had any leaks. If so is it a standard size for all?
I have read that the front axle really needs the specific Polaris fluid for the 4x4 to work properly but can I use generic fluid for the trans? I assume normal gear oil for the rear axle?
any help would be appreciated!
Old Sep 8, 2017 | 07:48 AM
Drain and fill plugs have a rubber o-ring that fits under the head. You can in most cases order these separate from places like here Polaris ATV Parts or a good hardware store can have ones that fit. They can seep fluid over time and if it gets too low you can have problems. The front diff did have a couple different fluids at one time but they changed that to where Demand Drive Plus is good for all diffs.If you don't have an owners manual here's a good 5 buck service manual that can help on fluids used,repairs and maintenance.Just pick your year model.Polaris ATV Service Manuals PDF Download Use Polaris AGL or equivalent oil suitable for chain driven gear cases such as Amsoil gear case lube. Rear diff you can use 80/90 GL4 or 5 in place of the Polaris Angle drive fluid.
Old Sep 8, 2017 | 10:42 AM
thedon's Avatar
Thank you Old Polaris Tech. I bought the manual - great deal for 4.95!
