2013 550 Sportsman Shifting problem
Awfully low mileage to be having problems like this. Pull the shift linkage from the belcrank on the gear case and see if you can manually get it to shift into park using vice grips on the belcrank. Rocking the atv back and forth a little may help. If it still doesn't shift,could be a problem in the gear selector (#10) or the park pawl or spring #7 and 9.Polaris ATV Parts 2013 A13ZN55AA-AQ-AZ SPORTSMAN 550 DRIVE TRAIN, MAIN GEARCASE SHIFT FORKS Diagram
