2013 550 Sportsman Shifting problem
Old Sep 15, 2017 | 06:20 PM
mrprint's Avatar
Default 2013 550 Sportsman Shifting problem
I have a 550 EFI sportsman. 500 miles. It will not go into reverse or park. Any suggestions as to what might be causing this? (hoping for an easy fix)
Old Sep 16, 2017 | 03:06 AM
mtpockets's Avatar
Sub for outcome.
Old Sep 16, 2017 | 04:34 AM
Awfully low mileage to be having problems like this. Pull the shift linkage from the belcrank on the gear case and see if you can manually get it to shift into park using vice grips on the belcrank. Rocking the atv back and forth a little may help. If it still doesn't shift,could be a problem in the gear selector (#10) or the park pawl or spring #7 and 9.Polaris ATV Parts 2013 A13ZN55AA-AQ-AZ SPORTSMAN 550 DRIVE TRAIN, MAIN GEARCASE SHIFT FORKS Diagram
Old Sep 17, 2017 | 09:20 AM
mrprint's Avatar
Thanks. I’ll try, but I’m no mechanical genius. Appreciate your help. I’ll let you know how it goes.
