Dang limp mode won't reset
Old Sep 17, 2017 | 12:16 AM
J s Wild's Avatar
Default Dang limp mode won't reset
New to the quad gig here, seen a lotta good info, I need to re ask a question that I've seen a few threads on. Have an 05 arctic cat 650 v2 4x4, can't get limp to reset. Have done all the recommendations, every reset video and forum I can find. Limp mode won't reset. Changed belt, flipped switch, jumped plugs, yadda yadda. Will not reset. Is there a way to bypass the switch? It would be a normally open switch right? Can I not just jump it, or slap a relay in there to get by, or is there a deeper problem that I haven't heard about?
Old Sep 17, 2017 | 10:06 AM
Zrock's Avatar
Super Quad Patrol
Depends why limp mode was activated. Their may be a bigger issue causing it to come back as soon as you fire machine. Mine limp mode went away on its own as soon as the issue was fixed..
Old Sep 17, 2017 | 11:18 AM
J s Wild's Avatar
Such as? I can't seem to find anything that goes into more detail on what could set it off.
Where's the best place to find repairs book?
Every time I try, all I get is hits on 04,06 models. I'd feel better if I had an actual book instead of a PDF.
Old Sep 17, 2017 | 11:24 AM
Zrock's Avatar
Super Quad Patrol
Just take the pdf to your local printer may be cheaper than buying a service manual from the dealer.. I just usually print off the pages I need at the time
Old Sep 17, 2017 | 01:09 PM
J s Wild's Avatar
Good idea. Do you know of other problems that could trip that switch? I plan opening up the cover again to see if tripped, kinda odd with a brand new belt, but I gotta start somewhere.
Old Sep 17, 2017 | 09:22 PM
Zrock's Avatar
Super Quad Patrol
