Can someone please help!!. I took apart my new Artic Cat Altera to rust proof it as it is used mostly at the beach.
All went perfectly until I had to reconnect the solenoid and I have 3 cables left to connect but I am unsure where to connect them to.
There are 2 black cables and one red cable (see attached picture).
The solenoid terminals are marked 'B' and 'M'.i am almost certain that 'B' is for the red cable going to the battery positive.
'M' is for the motor and connects to the cable that goes to the started motor. It is the last black cable that I am not sure what terminal on the solenoid it goes to.
I would imagine the wiring is the same for most late model Artic Cats. Could someone please help me check.
Thanks a mill in advance.
Cables i need to know what terminal on solenoid they attach to. Solenoid, showing the 'B' and 'M' terminals
I looked at my 2014 AC 700. it's completely different, but both are hot + lines. Mine has 2 large red cables, btw. Anyway, good time to spray with a rust protectant.
No expert, but I believe the solenoid only interrupts the power. I'd guess the green and green and yellow wires come from the ignition switch. I think if you jump the wire out with 12 volts, the starter will engage. Nice ATV, btw.
