Jetting question 250X
Old Apr 19, 2001 | 08:23 AM
HP500EFI's Avatar
Guys, have a jetting question for you on my wifes 91 250X. Recently installed a Supertrapp 4" Racing series exhaust and K&N filter. I have bumped up the main jet accordingly.
When I start the machine up, it starts immediately however as soon as it warms up, it is very hesitant when giving it gas. If I raise the choke lever to the first notch above "no choke", it runs and throttles just right. To me, it sounds as though it is running lean at 1/8 to 1/2 throttle. My question is what jet is inside the carb that needs to be changed? is it the pilot jet?.
I want to go to the dealer to get a new larger jet but need to know which one it is I need.
Thanks
Old Apr 19, 2001 | 12:14 PM
RotGutBottom's Avatar
For jetting questions...
call K&N Dynojet 702-399-1423 or 1-800-992-4993
They were a big help for me...
Old Apr 20, 2001 | 08:47 PM
krabill's Avatar
prob put somthing back in the carb wrong, I had the same pipe b4 I put my 350 motor on, I rejetted like 10 times and I did put somthing just not quite right back once and she acted just like that. I would pull it off again, it only takes like 5 minutes if you have the right stuff.
l8r
91 TRX350X
85 ATC250R
86 200x, now locked up..
Old Apr 23, 2001 | 08:49 AM
HP500EFI's Avatar
All fixed, actually I took the entire carb off and dismantled it and cleaned everything including the fuel petcock/assembly that is mounted to the tank.
Put everything back together and all runs just like it should. I am sure that something was partially plugged.
Thanks guys.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
