comparision sports & mag
Old Apr 19, 2001 | 10:21 AM
sxr6's Avatar
How about an honest comparision between the 335 Sportsman & 335 Magnum? Which rides better? Is the sportsman worth the extra $$. I do like the solid rear axle for it's strength & less maintainence.
Old Apr 19, 2001 | 10:38 AM
OffRder15's Avatar
They no longer make the Sportsman 335. It was replaced with the Sportsman 400. But if your looking for a used one, the Sportsman will definately have a better ride. I'm not dissin the Mag either, cause that thang got a sweet ride too. The Sportsman has a couple more grease zerks than the Mag, and it also has a couple more inches of ground clearance. It's really something you gotta check out for yourself. If you feel more comfortable on IRS, then go for the Sportsman. But, if your more confident with a solid axle, then the Mag will fit right in. Take a test ride.
Old Apr 20, 2001 | 08:20 AM
POLECAT's Avatar
THE MAGNUM IS A 325 NOT A 335. I WENT WITH THE 4X4 325 JUST BECAUSE I HAVE A MAGNUM 500 4X4.I HAVE HAD NO PROBLEMS AT ALL.AS FOR AS THE RIDE TO ME THERE IS NOT ALOT OF DIFFERENCE BETWEEN THE 335 AND 325.HEY,GOOD LUCK IN WHATEVER YOU CHOOSE.
Sep 30, 2015 01:37 AM
Hack714
Sep 26, 2015 08:11 AM
cboler9
Sep 24, 2015 08:35 PM
kampswas
Sep 23, 2015 05:05 AM
Hack714
Sep 20, 2015 05:54 PM
