pipes
Old Apr 18, 2001 | 08:34 PM
99sport400's Avatar
are rcr 400 pipes any good?
how do they fit?
Old Apr 19, 2001 | 12:20 AM
TheQuadfather's Avatar
The performance is good. I was disappointed with the fit. The silencer is held on with a hose clamp, and I could never get a tight fit out of it. Rick should consider adding some springs to hold them together, like the HPD setup.
Old Apr 19, 2001 | 11:31 AM
wolp's Avatar
I have a 99 Scrambler 400 with an RCR midrange pipe and silencer. The pipe and silencer went on without any problems and the fit was excellent. The silencer is connected to the pipe with a clamp. Rick used to use hose clamps but I believe he has switched to the clamp he provided me which is much stronger and holds tighter. I have no complaints with the pipe or silencer whatsoever. The performance has been excellent and the setup sounds great.
Old Apr 19, 2001 | 11:36 AM
adamnieman's Avatar
The power is great-very comparable to HPD as far as power.
Yeah, springs are better then clamps. My pipe seems to be staying in place good. I used lock nuts to hold everything in place. I also put the silencer clamo in the back notch on my Scrambler frame. No rattles now!
'96 Scrambler w/RCR Stage 1 Kit, K&N filter, and Boyesen Power Reeds
Old Apr 19, 2001 | 10:35 PM
99sport400's Avatar
does the pipe hit the frame anywhere?
i tried a fmf and thi pipe hit the frame by the shifter and hit the recoil starter housing so i returned it> i wanna know if rcr is any better fit.
does it use the stock headpipe that is about 4** long? or is all 1 piece?
alos i would like to see a pic of one on a sport 400
Old Apr 20, 2001 | 11:20 AM
adamnieman's Avatar
The RCR pipe is a one peice pipe. You will not use the stock extention with this pipe.
The pipe fits well and does not touch the frame. I had to turn my stift linkage upsidedown so it would not rub on the pipe.
'96 Scrambler w/RCR Stage 1 Kit, K&N filter, and Boyesen Power Reds.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
