Could my problems be caused by the float in the fuel tank????
Old Oct 8, 2017 | 10:32 PM
maybehonda's Avatar
Default Could my problems be caused by the float in the fuel tank????
I have a 2010 Arctic Cat 550 TRV ATV.
Fuel has been getting into the crank case.
I had it narrowed down to
-timing
-injector needs replacing.
But I was thinking today someone mentioned it could be caused by the float in the gas tank sticking or needing adjusting. I know my gas gauge doesn't work anymore. It never says it has as much gas as I know it has.
Could a float be causing my problems? How do floats work in EFI machines?
Old Oct 9, 2017 | 10:25 AM
Zrock's Avatar
Super Quad Patrol
someone probably thought you had a carbed machine and was talking about the float in the carb bowl needing adjusting or replacing. Your efi so you do not have one. I would almost bet its a dirty clogged injector that's leaking down.
Old Oct 9, 2017 | 11:24 AM
DirtDevil101's Avatar
I'm with Zrock...EFIs fuel is under pressure controlled by the injector...if the injector is stuck open fuel will flow until the pressure is relieved...possibly flooding the engine...
