2018 570 sportsmen Utilty Edtion
Just bought 2018 sportsmen utility edition. Comes with variable low speed limiter. Nothing in the manual or on the web on how to use it. Anyone know how to activate it or use it?
No idea. The website says Variable Low Speed Limiter (Set 7-14 mph for Spraying, Mowing, or Other Work) but that's all. I would ask the dealer about it. There should be a supplement to the owner's manual covering it.
From ATV.com write up article: low-speed limiter which allows the rider to set the maximum speed between 7-14 mph (11.3-22.5 kph) in 1-mph (1.6-kph) increments, making it ideal for spraying and low-speed tasks; work-specific gearing with lower gear ratio provides more low-end torque.
As for use...owners manual will give instructions on that. Probably a setting on the instrament cluster menu.
