Polaris 90cc sportsman oil leak front chain shaft
Old Oct 22, 2017 | 08:49 AM
combatlouie's Avatar
Default Polaris 90cc sportsman oil leak front chain shaft
i have a 2013 Polaris sportsman 90. The bolts holding the rear ended got loose causing the chain to get loose and tighten. That added pressure on the front sprocket, shaft, and bearing.
Well now now I have a bad bearing and an oil leak at the front sprocket shaft.
How would i remove the bearing? Can it be done from the out side or do I have to remove the cover and press it out from the inside.
combatlouie
Oct 22, 2017 08:35 AM
mikesjunk
Jan 3, 2016 07:16 PM
RickRitter
Nov 7, 2002 12:38 AM
NotuRaptor
Aug 23, 2001 05:09 PM
