04 Suzuki Ozark 250 won’t rev
Old Oct 28, 2017 | 05:03 PM
ozark250.'s Avatar
SuzukiOzark250 Enthusiast
Default 04 Suzuki Ozark 250 won’t rev
Hi everyone, hope I can get a solution to this,
I have a 2004 Suzuki Ozark 250. After it sat for 6 months to a year in my basement and then we took it out to start it. Put new gas in and it wouldn’t start. I then ordered a new petcock, and soaked the carburetor in carb cleaner. Put everything back together, choked it and started it. It started right up. The revs were high with the choke on so I turned the choke off and it shut off. After adjusting the idle and then other adjustment screw it idled good without the choke on. I then started to give it gas and it bogged down quickly and died. I kept adjusting it again and again but still won’t rev. I decided to take it for a ride with the choke on. It would start revving higher but once I got to about 10% throttle it would not rev any higher and would buck a little bit sometimes at every throttle position after 10%. I took apart the carb and cleaned it out again but still same problem. Has anyone had this problem or does anyone have any suggestions? Thanks
