2011 500 sportsman camshaft
Old Oct 29, 2017 | 06:07 PM
joaa's Avatar
Default 2011 500 sportsman camshaft
The cap on the left side of the cam cover cracked and spewing oil. I removed the cap and found pieces busted and pins sheared.
I noticed the cam has way lots of side to side play like a thrust bearing was broken or missing also. Before I tear it down I want to make sure how the timing sprockets are set for alignment and what the purpose the parts inside the cap have. Ideas? Thanks.
Old Oct 29, 2017 | 08:09 PM
Cam compression release lever and spring along with the stop pin on the left side. Cam rides in a milled cavity in the head.Cam shouldn't have any play. Possible that the head is damaged,but best to tear it down and inspect. Highly suggest a cheap manual to acquaint yourself with this engine. Shows how to time the cam back up,etc.2011 Polaris Sportsman 500 HO Service Manual PDF Download
