Sportsman 850xp torque specs
I've found countless 2011 sportsman 850xp service manuals for free. I suggesting going that route because they're the same exact manual.
Ive paid the $5 in hopes they would have a process of marrying the engine and trans together (2009 & 2010 are different)
if anyone else is stuck on this I've found that if you place the motor so it's starting to go on & use 4 engine mount bolts (without the nuts obv) (2 on one side, 2 on the other) and tighten them in a cross pattern, it will pull the motor in so you can start the short bolts thatre ment to be there. NOTE make sure you align the trans & motor or else you could rip or tear your rubber grommet.
Most manuals address the engine and transmission separately and aren't always clear cut. There are short cuts for just about everything,but you also have to be careful using threaded holes in aluminum cases to pull assemblies together. Strip out case holes and you may have a bigger problem on your hands.Anyway glad that you have it back together.
I looked through the engine & transmission sections but only found the removal process in the engine section with only install notes. Also these motors don't have a thrust ring to keep the crankshaft from "walking" my buddy had that happen to him. Ended up needing new crank bearings $100 & case halves $1300! Terrible design imo
Yes the manuals do say that a lot..
