Gaps in body around headlight 570 (2016)
Old Nov 5, 2017 | 06:00 PM
RticKwad's Avatar
Runs Stealth!
Default Gaps in body around headlight 570 (2016)
All,
looking at my front end today I wondered if my ATV
Is properly fitted around the headlights? I never removed it or bumped it?
Old Nov 5, 2017 | 06:26 PM
WilliamBos's Avatar
That's normal - it's a Polaris. Fit and finish are not top priority for them.
Old Nov 5, 2017 | 06:41 PM
Screwed in with u-nuts to the cab,but have o-rings like the older models also. Check the o-rings plus you can see if the head light adjuster helps any as far as gaps.
Old Nov 5, 2017 | 07:37 PM
RticKwad's Avatar
Runs Stealth!
Good info. Thanks OPT, so I take while not uncommon it its not normal? Mine is showing more space than it should?
Thanks,
R'
Old Nov 6, 2017 | 01:58 PM
I just figured they needed extra room for headlight adjustment.
Old Nov 6, 2017 | 04:15 PM
hydrex's Avatar
I'd check head light alignment first. Then I wouldn't worry. If everything is put together, it looks ok to me. It's called close enough.
