2) Chassis problems.. If your quad runs but you have other problems.. post in here.
Chinese mini atv 49cc Suspension upgrade
Old Nov 6, 2017 | 08:59 AM
Tiago Lopes's Avatar
Default Chinese mini atv 49cc Suspension upgrade
Hello, just bought a mini atv for my son, and the suspension is rock hard, most of the time rides in 3 wheels because its so hard. The shocks measure 150mm rear and front, can i mount bigger shocker (200mm) so i stay higher and the shocks will have some course? Where can i buy this shocks online?
Tiago
from Portugal
Old Nov 6, 2017 | 02:25 PM
DirtDevil101's Avatar
150mm are really small shocks...installing longer shocks can create positive chamber on the front wheels \ / and your swing-arm in the rear may not drop out enough to get a longer shock in...
Old Nov 11, 2017 | 10:07 AM
Zrock's Avatar
Super Quad Patrol
what air pressure are u running in the tires? Don't use what is stamped on the outside of the tire..
Old Nov 11, 2017 | 10:17 AM
Hi, and thank you for the help, i inflate the tires until they were hard, what pressure ir recommend? My son weights 23kg
Old Nov 13, 2017 | 11:40 AM
8-10 psi...
