1995 magnum 425 regulator
Old Nov 7, 2017 | 01:03 PM
BREKS's Avatar
Default 1995 magnum 425 regulator
Need help with wire colours. replacing my voltage regulator but the wire colours are different. anyhow. i n3ed to know what colour wire coming from the stator is for the stator centretap
Old Nov 7, 2017 | 02:43 PM
LR37 regulator. Yellow,Yellow/Red,Yellow/Brown from the stator to the regulator. Regulator red wire hooks to the supplied harness red power wire.
Old Nov 7, 2017 | 05:35 PM
BREKS's Avatar
so the old regulator has 2 black wires with white tracers. a solid black. a red and a brown. the new regulator has brown, red, yellow/red, yellow and a black/yellow.
Old Nov 7, 2017 | 05:50 PM
Sounds like you're getting the reverse limiter in there especially with that solid black wire. Get the pdf manual for 5 bucks and it has the wiring schematics and anything else you need. Both the 2x4 and 4x4 share the same regulator.1995 Polaris Magnum 4X4 Service Manual PDF Download
Old Nov 7, 2017 | 06:30 PM
BREKS's Avatar
have the manual, didn't really help. here is the regulator
Old Nov 7, 2017 | 06:47 PM
Ok,then hook the red to red, solid yellow to stator yellow,yellow/red to stator yellow/red,yellow/black to stator yellow/brown wire.Brown wire is a ground and shows a connection for it also.
Old Nov 7, 2017 | 07:00 PM
BREKS's Avatar
okay, that was what i was assuming but didnt want to hook it up wrong and fry something. because the only one that didnt have a match is the stator yellow/brown. and the regulator black/yellow
Old Nov 7, 2017 | 07:12 PM
A lot of aftermarket regulators don't match colors correctly. Main ones to match are the red,yellow,yellow/red. What one is left over just hook it to the last stator wire. In your case stator yellow/brown to regulator yellow/black. If it has a bullet connector on the brown regulator wire,looks like you can pull the brown ring connector wire that's grounded to the old regulator and chunk it.Then insert the brown regulator wire in its place on the harness ground connector.
Old Nov 7, 2017 | 07:40 PM
BREKS's Avatar
i will give that a try. quad runs good but 22v out of the regulator seems a bit high so im changing it out
Old Nov 8, 2017 | 06:44 AM
Yes 22 volts,way too much. Can fry a battery fairly quick and can on occasion short out cdis.Good that you caught it in time.
